Exclude folder when downloading
I am taking over some work that was done by someone and I need to make some adjustments. However, I am not really good with PowerShell..any help is appreciated.
The script has to copy files from the sftp server to a folder locally. However, it should do this only copying the files in the specific folder and exclude any subfolder of each given source location.
After reading some documentation this is how far I got. However, this doesn't work...I am probably doing something wrong..just don't know what.
Add-Type -Path "C:\Windows\System32\WindowsPowerShell\v1.0\Modules\Winscp\WinSCPnet.dll" #PassPhrase $Password = ConvertTo-SecureString 'XXXX' -AsPlainText -Force $sessionOptions = New-Object WinSCP.SessionOptions -Property @{ Protocol = [WinSCP.Protocol]::Sftp HostName = "XXXXX" UserName = "XXXX" Password = "XXXX" PortNumber = 11111 SshHostKeyFingerprint = "XXXX" SshPrivateKeyPath = "C:\key\PrivateKey-UAT01.ppk" PrivateKeyPassphrase = "XXX" } $session = New-Object WinSCP.Session $session.SessionLogPath = "C:\logs\winscpprod_pull.log" # Connect $session.Open($sessionOptions) #Download files $transferOptions = New-Object WinSCP.TransferOptions $transferOptions.TransferMode = [WinSCP.TransferMode]::Binary $transferOptions.ResumeSupport.State = [WinSCP.TransferResumeSupportState]::Off #VAR $Source1 = "/OUTPUT/" $Source2 = "/OUTPUT/1/" $Source3 = "/OUTPUT/2/" $Source4 = "/OUTPUT/3/" $Source5 = "/OUTPUT/4/" $Destination1 = "C:\Bla\1\" $Destination2 = "C:\Bla\2\" $Destination3 = "C:\Bla\3\" $Destination4 = "C:\Bla\4\" $Destination4 = "C:\Bla\5\"
$session.GetFiles( $Source1 -filemask= /OUTPUT/1;/OUTPUT/2/" , $Destination1, $False, $transferOptions)
