Direct access?
sigdell
Slovenia
Direct access?
When I login to my server, I have to click through a series of folders to get to mine. Is there a way to make WinSCP access my folder directly and thus eliminate this repeating click session?
The host name is an IP number. I tried to attach a path, but it didn't work.
Greetings
JanErik
_________________
janerik
Re: Direct access?
You can setup the directory as a default path, you can store it as a bookmark, you can type full path into "open directory" dialog. There are plenty of options. See documentation for navigation.
