Download with Winscp fails while PSCP is working
I'm try to download a file from a Unix server, but I always get the error message:
Host is not communicating for more than 15 seconds.
Still waiting...
Note: If the problem repeats, try turning off 'Optimize connection buffer size'.
Warning: Aborting this operation will close connection!
I also deactivate the "Optimize connection buffer size", but the problem still exits. When I download the file with pscp, everything works well.
I have the problem with downloading of the file on every machine. So maybe some settings are wrong?
Has anybody a hint to get rid of this problem?
PS: I use Version 5.17.7 (Build 10640)
Thanks for your support.
Manuel
Still waiting...
Manuel
