Long pauses between files during copy process...
4k3or3et
Hi Guys,
i am running SSH Server on Android Device. The problem is that when folder contains a lot of files (8,5K in my case, usually not bigger than 500KB) then there are long pauses between each file being copied. I think it may be actually refreshing folder content after file copied. Could that be the reason?
I am using SFTP protocol.
I am using winscp.com command line script but winscp.exe GUI is the same.
Is there anything I can do on WinSCP side to speedup the copy process in my case?
Thank you.
Re: Long pauses between files during copy process...
4k3or3et
Thank you for your reply. I am attaching the log.
In this session I was uploading 6 files, total 2.4MB in size. Operation tool 3 minutes and 5 seconds. Files which were uploaded:
If there is anything on WinSCP side I can do to speed up the process where there are a lot of files in directory please let me know.
  • winscp.log (2.05 MB, Private file)
> 2020-08-24 18:12:54.765 Type: SSH_FXP_OPEN, Size: 62, Number: 15875
< 2020-08-24 18:13:19.444 Type: SSH_FXP_HANDLE, Size: 45, Number: 15875
It seems that the server takes long time to create the new file. I cannot tell why.
