WinSCP timing out when connecting to Sharefile sites
Guest23072020
Hi, my organisation has an automatic file downloading process which uses WinSCP to connect to different FTP sites and download files. Two of these FTP sites are running on Sharefile. In recent weeks, WinSCP has been timing out sometimes when connecting to the two Sharefile sites, but is still fine with the other sites. It seems that Sharefile has some kind of recurring problem. I can connect manually without problems. Has anyone else been experiencing anything like this?
Re: WinSCP timing out when connecting to Sharefile sites
Can you post logs both from the failed automatic login and successful manual login?
Hi, I don't know how to get a log from a manual login, but this is what a failed automatic login log looks like:
. 2020-07-28 04:02:09.394 Transfer Protocol: FTP
. 2020-07-28 04:02:09.395 Ping type: Dummy, Ping interval: 30 sec; Timeout: 15 sec
. 2020-07-28 04:02:09.395 Disable Nagle: No
. 2020-07-28 04:02:09.396 Proxy: None
. 2020-07-28 04:02:09.397 Send buffer: 262144
. 2020-07-28 04:02:09.398 UTF: Auto
. 2020-07-28 04:02:09.399 FTPS: Implicit TLS/SSL [Client certificate: No]
. 2020-07-28 04:02:09.400 FTP: Passive: Yes [Force IP: Auto]; MLSD: Auto [List all: Auto]; HOST: Auto
. 2020-07-28 04:02:09.401 Session reuse: Yes
. 2020-07-28 04:02:09.402 TLS/SSL versions: TLSv1.0-TLSv1.2
. 2020-07-28 04:02:09.402 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2020-07-28 04:02:09.403 Cache directory changes: Yes, Permanent: Yes
. 2020-07-28 04:02:09.404 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2020-07-28 04:02:09.404 Timezone offset: 0h 0m
. 2020-07-28 04:02:09.405 --------------------------------------------------------------------------
. 2020-07-28 04:02:09.590 Connecting to ***********.sharefileftp.com:990 ...
. 2020-07-28 04:02:24.607 Timeout detected. (control connection)
. 2020-07-28 04:02:24.609 Connection failed.
It works sometimes, so the impression that I get is that the intermittent problem is at Sharefile's end and I'm not sure there's much I can do; I was wondering whether other people have had recent problems with Sharefile as well. Thanks for any help.
