Powershell example in Protecting credentials used for automation doesn't work
tbowar
Minnesota, USA
After reading through the Protecting credentials used for automation section in the docs, I copied the Powershell code and created a script to test it:
# Read XML configuration file
[xml]$config = Get-Content "D:\test\configs\mediaserver.xml"
Write-Host $config.Configuration.Password
# This writes the correct password to the screen
# The session won't open with this code:
# Set up session options
    HostName = "usefulmedia.com"
    UserName = "gplimpton"
    Password = $config.Configuration.Password
    PortNumber = "2222"
# The session opens correctly with this code:
    Password = "actualpasswordstring"
    PortNumber = "2222"
Do I have a syntax error? Why isn't WinSCP substituting $config.Configuration.Password correctly for the actual password?
Re: Powershell example in Protecting credentials used for automation doesn't work
What does it mean "won't open"? Please be more specific.
Definitely, this is not about "WinSCP substituting $config.Configuration.Password correctly for the actual password". The $config.Configuration.Password must be containing a wrong password in the first place. There might be a small difference that you do not notice (like a whitespace or a wrong encoding).
Compare outputs of:
Write-Host ([System.Text.Encoding]::UTF8).GetBytes("actualpasswordstring")
Write-Host ([System.Text.Encoding]::UTF8).GetBytes($config.Configuration.Password)
tbowar
Minnesota, USA
Fixed
Martin,
I did paste your test code in and it showed that the $config.Configuration.Password variable matched the actual password.
To be honest, I am not sure why it didn't work, all I know is that I got an error when trying
session.Options with $config.Configuration.Password. When I changed the code a little more, it started working.
Thank you for your response.
