Progress Bar for Keep Local Directory up to Date
heax
Hi there
I use the Keep Local Directory up to Date script to get data from remote sftp servers that are connected via a 4G SIM-cards. When starting the script, the user (I) only get two lines
Connecting...
Synchronizing changes...
And that's it.
It would be really nice to have some kind of progress bar or an output of some sort to reassure the user (me) that things are still going well.
Thank you for WinSCP!
Best regards, Axel
Re: Progress Bar for Keep Local Directory up to Date
Thanks for your suggestion. I'll try to improve the script.
Can you send me an email, so I can send you back an improved version of the script for testing, once I have it? Please include a link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
