How to use custom commands to zip files on task scheduler export job
cerkaz
I've been using following line from https://winscp.net/eng/docs/guide_schedule to export csv files to our FTP.
/log=c:\path\winscp.log /command "open sftp://user:password@example.com/" "put -delete d:\*.csv /home/user/" "exit"
It works fine, but due to the big size of the csv i would like to zip them.
I read that
zip -r "!?&Enter an Archive Name:?archive.zip!" !&
could be used, can i implement that to the task scedule line?
Re: How to use custom commands to zip files on task scheduler export job
WinSCP cannot zip files.
You have to zip them before starting WinSCP.
If you currently start WinSCP directly in the Task Scheduler, you will have to wrap WinSCP call to a batch file (or PowerShell script or any another script of your preference). And within the batch/script, run zip before starting WinSCP.
For an example of a wrapper batch file, see:
https://winscp.net/eng/docs/guide_debugging_scheduler#output
