Directly write contents of a string object to the remote file
Gert.Broekhaar@rivm.nl
Being aware that my question perhaps is not in line with the SCP-protocol, I wondered if it is possible to directly write the contents of a .NET string to the remote file? Using the PutFiles-method I see that the first two parameters are localPath and remotePath. I would like to skip the step of first writing the string contents to a local file and then using the PutFiles but the method doesn't seem to have an overload to support this approach. Is there a way to accomplish this with WinSCP?
Thanks very much,
Gert
Reply with quote E-mail
Re: Directly write contents of a string object to the remote file
It's not supported in the current version of WinSCP.
The next version of WinSCP will supporting streaming with SFTP protocol:
https://winscp.net/tracker/1738
I can provide you a development build, if you want to try it.
tj
US
Development build
I was wondering if it would be possible to get the dev build with support for streaming with SFTP protocol (5.18), so I can try it and see if it will meet my needs?
Thanks!
Re: Development build
Sent to your email.
sara.m_@...
Hello Martin,
I have the same problem as Gert and I would like to put one file from a Stream without writing it first on disk. Could you send me the development build too please (both the .exe and the .dll)?
Thank you very much.
Sara
Sent.
