Quality of life: speed of comparison of local and remote folder with many files
pier4r
Example: have two folders, one local and one remote, with thousands of files each (say 2500).
Do the comparison (basic setup, no changes for the comparison tool). It takes quite a bit. Now I am aware that with 2000 elements, there are 4 million comparisons (and if it is based on size, datestamp, name it is 3 times 4 million), but they should be a breeze on whatever CPU that is not from the 90s. Instead on a A10 CPU (5750M) it takes between 10 to 15 seconds to compare. Of course it is not that tragic, but could it be improved or is it really "nice to have"?
Thanks!
Re: Quality of life: speed of comparison of local and remote folder with many files
