-certificate switch?
gregb
WinSCP 5.17.3
WinSCP seems to be disregarding server certificates and automatically connecting to our partners, regardless of the certificate being offered. I'm using WinSCP.com via. powershell. I know that a mistyped -certificate in the OPEN statement would previously cause the connection to fail (as it should) but I cannot remember how long ago that was, nor which WinSCP version that was. I've been using these scripts for a number of years, and the last certificate key update to this script was about 2 years ago.
Whether I connect with the valid certificate, an invalid certificate, or no certificate, this FTPS connection succeeds:
PS C:\Windows> & "C:\program files (x86)\winscp\winscp.com" /command `"option batch abort`" `"option confirm off`" `"option exclude *downloaded*`" `"open ftps://USERNAME:password@ftpsite.company.com -passive=on -certificate='"31:a0:0f:ff:69:cc:9b:d5:10:df:98:36:b8:74:a5:9b:62:27:b1:87"' -rawsettings FtpForcePasvIp=1 ftps=2 fsprotocol=5 portnumber=20021`" `"lcd d:\abc`" `"dir`" `"exit`"
batch           abort
confirm         off
include         |*downloaded*
Connecting to ftpsite.company.com:20021 ...
TLS connection established. Waiting for welcome message...
Connected
Starting the session...
Session started.
Active session: [1] USERNAME@ftpsite.company.com
d:\abc
D---------   0                           0              ..
Drwxrwxr-x   0 USERNAME  FTP            256 Jun 15 2014  inbound
Drwxrwxr-x   0 USERNAME  FTP            256 Jun 15 2014  outbound
Invalid Certificate
PS C:\Windows> & "C:\program files (x86)\winscp\winscp.com" /command `"option batch abort`" `"option confirm off`" `"option exclude *downloaded*`" `"open ftps://USERNAME:password@ftpsite.company.com -passive=on -certificate='"aa:aa:aa:aa:aa:aa:aa:aa:aa:aa:aa:aa:aa:aa:aa:aa:aa:aa:aa:aa"' -rawsettings FtpForcePasvIp=1 ftps=2 fsprotocol=5 portnumber=20021`" `"lcd d:\abc`" `"dir`" `"exit`"
batch           abort
confirm         off
Connected
Session started.
d:\abc
D---------   0                           0              ..
No Certificate
PS C:\Windows> & "C:\program files (x86)\winscp\winscp.com" /command `"option batch abort`" `"option confirm off`" `"option exclude *downloaded*`" `"open ftps://USERNAME:password@ftpsite.company.com -passive=on -rawsettings FtpForcePasvIp=1 ftps=2 fsprotocol=5 portnumber=20021`" `"lcd d:\abc`" `"dir`" `"exit`"
batch           abort
confirm         off
Connected
Session started.
d:\abc
D---------   0                           0              ..
PS C:\Windows> exit
Have I cached the certificate somewhere and it's overriding the CLI? I did clear the cached hosts keys (Tools > CleanUp)
I did try several of our partner sites via. WINSCP GUI and none of them prompted me to accept a hostkey.
I tried running WINSCP 5.7.6 on a new system and got the same results.
Has something changed over time that I've missed in the release notes?
Graciously,
Greg
Re: -certificate switch?
gregb
winscp.log attached
Hi Martin,
Log file attached. I was able to successfully connect with:
-certificate=aa:aa:aa:aa:aa:aa:aa:aa:aa:aa:aa:aa:aa:aa:aa:aa:aa:aa:aa:aa
Greg
  • winscp.log (11.46 KB, Private file)
Description: sanitized log
Re: winscp.log attached
Your log files shows that the certificate is signed with a trusted authority, so the -certificate switch is not needed.
. 2020-06-29 08:51:34.074 Certificate verified against Windows certificate store
