sftp get command to send exact number of files only with filename like IX*.TXT
haleem02
Malaysia
Hi Experts
I am new to this.
Using winscp 4.2.7 on windows server 2012
My requirement: The files should transfer only when count is 3 and filename like IX*.TXT from Linux server to Windows server using WINSCP bat file.
Is there any option to get command to send only when count is 3 and filename like IX*.TXT ?
Re: sftp get command to send exact number of files only with filename like IX*.TXT
It's not difficult to implement using WinSCP .NET assembly and for example PowerShell script.
Use Session.EnumerateRemoteFiles to retrieve list of files matching your criteria, then check that there are three of those and download.
https://winscp.net/eng/docs/library_session_enumerateremotefiles
Btw, you urgently need to upgrade. WinSCP 4.2.7 is 10 years old.
