Authentication failed during session connect when using assembly
sarahN
I got this error while connecting to the session:
Connection has been unexpectedly closed. Server sent command exit status 0.
Using username "xxxxxx".
Authentication failed.
Saw few of the same issues as mine and you only asked for log.
Attached is mine.
thanks.
  • winscplogauthenticationerror.txt (5.7 KB, Private file)
Re: Authentication failed during session connect when using assembly
What is "AIX LAM Authentication"? Is your server using some multi-factor authentication?
sarahN
not sure about that because the server is our vendor's.
anyway, I've manage to connect to the server now by including the private key path in the session option.
thanks.
