Can't get proxy socks5 to scp host working
ron101
USA
Hello, I have winscp 5.17 and I am trying to get it to proxy to a socks 5 host and then connect to another host using ssh public key authentication.
I get the error
2020-05-05-28 09:12:32.704 Waiting for data timed out, asking user what to do.
2020-05-28 09:12:32.704 Asking user:
2020-05-28 09:12:32.704 **Host is not communicating for 15 seconds.
I think I have set up the proxy information and scp information correctly in winscp? I have added the ssh private key to the proxy authentication area. I have tested the basic socks 5 connection with a mobile shadowsocks application and am able to login successfully.
The shadowsocks socks5 server encryption method I'm using is chacha20-ietf-poly1305. Does winscp support this?
Here is the related logs.
external_host is the ip address of the socks5 server I am trying to connect to. internal_host is the ip address of the host I want to proxy to after connecting to the socks5 server. Thanks.
. 2020-05-28 09:12:16.004 --------------------------------------------------------------------------
. 2020-05-28 09:12:16.004 WinSCP Version 5.17.5 (Build 10414) (OS 10.0.18362 - Windows 10 Enterprise)
. 2020-05-28 09:12:16.004 Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\
. 2020-05-28 09:12:16.004 Log level: Normal
. 2020-05-28 09:12:16.004 Local account: DESKTOP-HDHGFHH\user1
. 2020-05-28 09:12:16.004 Working directory: C:\Program Files (x86)\WinSCP
. 2020-05-28 09:12:16.004 Process ID: 96
. 2020-05-28 09:12:16.004 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe"
. 2020-05-28 09:12:16.004 Time zone: Current: GMT-7, Standard: GMT-8 (Pacific Standard Time), DST: GMT-7 (Pacific Daylight Time), DST Start: 3/8/2020, DST End: 11/1/2020
. 2020-05-28 09:12:16.004 Login time: Thursday, May 28, 2020 9:12:16 AM
. 2020-05-28 09:12:16.004 Session name: proxy user1@external_host (Modified site)
. 2020-05-28 09:12:16.004 Host name: internal_host (Port: 22)
. 2020-05-28 09:12:16.004 User name: user1 (Password: No, Key file: Yes, Passphrase: No)
. 2020-05-28 09:12:16.004 Tunnel: No
. 2020-05-28 09:12:16.004 Transfer Protocol: SCP
. 2020-05-28 09:12:16.004 Ping type: Off, Ping interval: 30 sec; Timeout: 15 sec
. 2020-05-28 09:12:16.004 Disable Nagle: No
. 2020-05-28 09:12:16.004 Proxy: SOCKS5
. 2020-05-28 09:12:16.004 HostName: external_host (Port: 8399); Username: ; Passwd: Yes
. 2020-05-28 09:12:16.004 Send buffer: 262144
. 2020-05-28 09:12:16.004 SSH protocol version: 2; Compression: No
. 2020-05-28 09:12:16.004 Bypass authentication: No
. 2020-05-28 09:12:16.004 Try agent: Yes; Agent forwarding: Yes; TIS/CryptoCard: No; KI: No; GSSAPI: Yes
. 2020-05-28 09:12:16.004 GSSAPI: Forwarding: No; Libs: gssapi32,sspi,custom; Custom:
. 2020-05-28 09:12:16.004 Ciphers: aes,chacha20,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2020-05-28 09:12:16.004 KEX: ecdh,dh-gex-sha1,dh-group14-sha1,rsa,WARN,dh-group1-sha1
. 2020-05-28 09:12:16.004 SSH Bugs: Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto
. 2020-05-28 09:12:16.004 Simple channel: Yes
. 2020-05-28 09:12:16.004 Return code variable: Autodetect; Lookup user groups: Off
. 2020-05-28 09:12:16.004 Shell: default
. 2020-05-28 09:12:16.004 EOL: LF, UTF: Auto
. 2020-05-28 09:12:16.004 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes; Follow directory symlinks: No
. 2020-05-28 09:12:16.004 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No; Exit code 1 is error: No
. 2020-05-28 09:12:16.004 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2020-05-28 09:12:16.004 Cache directory changes: Yes, Permanent: Yes
. 2020-05-28 09:12:16.004 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2020-05-28 09:12:16.004 DST mode: Unix;Timezone offset: 0h 0m
. 2020-05-28 09:12:16.038 Leaving host lookup to proxy of "internal_host" (for SSH connection)
. 2020-05-28 09:12:16.038 Will use SOCKS 5 proxy at external_host:8399 to connect to internal_host:22
. 2020-05-28 09:12:16.038 Looking up host "external_host" for proxy
. 2020-05-28 09:12:16.038 Connecting to SOCKS 5 proxy at external_host port 8399
. 2020-05-28 09:12:16.038 Connecting to external_host port 8399
. 2020-05-28 09:12:16.145 We claim version: SSH-2.0-WinSCP_release_5.17.5
. 2020-05-28 09:12:32.704 Waiting for data timed out, asking user what to do.
. 2020-05-28 09:12:32.704 Asking user:
. 2020-05-28 09:12:32.704 **Host is not communicating for 15 seconds.
. 2020-05-28 09:12:32.704 Wait for another 15 seconds?** ()
. 2020-05-28 09:12:34.455 Attempt to close connection due to fatal exception:
* 2020-05-28 09:12:34.455 **Terminated by user.**
. 2020-05-28 09:12:34.455 Closing connection.
* 2020-05-28 09:12:34.488 (EFatal) **Terminated by user.**
Re: Can't get proxy socks5 to scp host working
I'm not aware of SOCKS using any encryption. So I'm confused by your reference to "chacha20-ietf-poly1305" with respect to the proxy.
The same for "I have added the ssh private key to the proxy authentication area".
Can you show us your configuration of "shadowsocks"?
ron101
USA
Here is the basic configuration of shadowsocks I'm following which has the method field where a user can specify the encryption they would like.
https://www.linode.com/docs/guides/create-a-socks5-proxy-server-with-shadowsocks-on-ubuntu-and-centos7/
Here is my shadowsocks configuration file.
    "server":"0.0.0.0",
    "server_port": 8399,
    "password":"thepassword",
    "timeout": 300,
    "method": "chacha20-ietf-poly1305",
    "fast_open": true
By ssh private key I mean the putty private key file.
I've attached a file with screenshots of my winscp setup.
I hope that it is possible to use winscp in this manner.
Client copying a file -> socks5server -> destination server receiving copied file(s)
Thanks!
