Opening Files in External Editor causes file group to change
jessebtmn
When I save changes to files using the internal editor, the group stays the same (desired behavior). However, I have saved the same files from the external editors Atom and Visual Studio Code and in both cases the group changed from 'mydevgroup' to 'myusername' meaning I have to be careful not to lock other devs out of files that I'm editing. Is this something I can configure in WinSCP?
WinSCP: Version 5.17.5 (Build 10414)
Windows 10 Pro: Version 10.0.18363
Re: Opening Files in External Editor causes file group to change
Please attach full session log files for both scenarios.
jessebtmn
Thanks for taking out the time to look at this. Here are my logs with redactions.
Description: This is me editing and saving file2.pl via the internal editor. The group stays as "devgroup".
Description: This is me editing and saving file2.pl via an external editor. The group changes from "devgroup" to "username1".
The file is over 100 KB. With the default settings, such file is transferred via a temporary file, what causes the overship change:
https://winscp.net/eng/docs/resume#automatic
You can turn that feature off.
https://winscp.net/eng/docs/ui_pref_resume
The reason, why it's different in the internal editor, is that the internal editor forces a use of text transfer mode. With the mode, the transfer via the temporary file is never used. So as another solution, you can force the text mode for your external editor.
https://winscp.net/eng/docs/ui_editor_preferences
