Why the last 1% takes so long time.
rainmanec
China
When I use .NET assembly to download a file, why the last 1% takes so long time.
At this time, the server side shows that the transmission is completed, but the client shows that the download is complete after several minutes.
I want to know the reason for this situation to optimize the software, thanks!
Re: Why the last 1% takes so long time.
