Automatic updates of local files
swbrains
I'm new to WinSCP and I've been able to edit a remote file and have it auto-update after saving the file, but I'm wondering if it's possible to edit a local copy of a file and have it update to the connected server after saving the local copy?
I saw the synchronization menu option but I don't want to synchronize everything so I'm really looking for uploading of the local file I just saved.
Thanks!
swbrains
Thanks. I was looking for an option that would do this automatically rather than requiring me to select this option each time I start the app.
When I do select this option after connecting to a server, it displays a dialog of options and I click Start. It then leaves the modal dialog open over the UI and I can't access the rest of WinSCP.
