Opening SSH Links in Kitty
TomT
UK
I've followed various posts on how to open SSH:// links using WinSCP to open Kitty.
When I click the link WinSCP opens as does kitty, bit it doesn't launch my saved kitty session.
It simply opens kittys main window, is there any way to do this using WinSCP ?
Re: Opening SSH Links in Kitty
Does "Open in PuTTY" command work for you (with KiTTY)?
How are you trying to make it work with "saved kitty session"? I do not think it is possible to refer to a saved session in URL.
