Controls vanish after remote sync started in 'new window' and then 'minimized to system tray'
Lorin
To reproduce:
1. Open 'Keep remote directory up to date' modal
2. After setup, select 'Start in New Window' option.
3. In the status modal, select 'Minimize to System Tray'
The modal vanishes, no tray icon appears and until you close the main window you cannot stop the process, nor restore the window.
Re: Controls vanish after remote sync started in 'new window' and then 'minimized to system tray'
Thanks for your report. I'll look at this and I'll contact you in few days.
https://winscp.net/tracker/1868
