Command-line Windows SFTP server
hendra
help, is winscp support access windows sftp server.
can i use windows command to run
session.executecommand
such as cmd /c start, chkdsk, schtasks /create.
thanks
hendra
Re: Command-line Windows SFTP server
Yes, Windows SFTP/SSH server is SFTP/SSH server as any other.
when i execute this string:
session.ExecuteCommand("cmd /c start calc.exe").Check()
it took a long time,even though the result is an error :
Connection has been unexpectedly closed. Server sent command exit status 0.
in log it write :
< 2020-05-04 10:23:10.836 [Shell]
it look like the command is not recognized.
Description: log winscp
It makes no sense to execute a GUI application in an SSH session. What do you expect it to do? Did you think it will open the GUI application in the interactive Windows session? It cannot. The SSH and interactive sessions are isolated.
hendra
what if i start application like schtasks, that not interactive/GUI application. its like sqldump isn't it??
Yes schtasks should work. But WinSCP Session.ExecuteCommand needs Linux shell. It won't work with Windows shell and Windows command. WinSCP is primarily an SFTP client. It's not the right tool to execute commands on SSH server.
