WinSCP - Local Panel - File list - Always gray background
sshalbert
the background color of the local panel is gray, instead of white. Files and folders are not hidden and are mine.
What's happening?
Thanks!
Description: Screenshot.
Re: WinSCP - Local Panel - File list - Always gray background
Is it just the color? Or is the panel actually disabled (cannot be worked with)?
mcoret
FullRowSelect?
Choosing FullRowSelect=1 makes background color in both panels to be gray (WinSCP 5.19.2), as in the screenshot above.
