AWS SSM / Session Manager support in WinSCP
mattisdada
I'm trying to hook up WinSCP and AWS SSM / Session Manager. But I cannot get it to work with current tooling... :(
My attempt was to use Advanced > Proxy. Specify proxy as local and use the following proxy command:
aws ssm start-session --target %host --document-name AWS-StartSSHSession --parameters 'portNumber=%port' --profile getnext --region us-east-1
But it appears as if WinSCP doesn't even get to that stage as it first looks for host (which is an AWS instance ID, not a valid host normally ie i-02633e980a031c37f.
AWS SSM would normally recommend to use .ssh/config with the following config:
host i-* mi-*
    ProxyCommand C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe "aws ssm start-session --target %h --document-name AWS-StartSSHSession --parameters portNumber=%p"
Any help would be appreciated or if native support for this feature was added in, that'd be great :)
Description: What current config looks like
Re: AWS SSM / Session Manager support in WinSCP
You probably have to turn on "Do DNS name lookup at proxy end".
Also if they recommend starting the aws via powershell.exe (though I have no idea why), then you should do the same in WinSCP.
If none of this help, please post a session log file.
mattisdada
Thanks for that Martin, don't know how I missed that option!
The only other thing I had to change to get it to work was changing ' to " in the parameter list. For whatever reason it doesn't like it.
Do you think it's worthwhile creating a small guide for this particular authentication option?
aws ssm start-session --target %host --document-name AWS-StartSSHSession --parameters "portNumber=%port" --profile <aws profile> --region <region>
Was my final proxy string
Invigor
Hi guys,
I'm also trying to get this working but the only way to get a successful connection is to pass a username and the associated PPK file via the SSH > Authentication setting.
This sort of defeats the purpose of using AWS SSM if we need to main user accounts and keys to set up an SFTP connection.
I assumed that my AWS credentials would be sufficient or am I missing something?
Thanks,
Michael
mattisdada
@martin: It would suit on that page yes :) . Short explanation on what SSM is, it's basically just a way of SSHing into a server without the need of network access, it's also possible to use it without requiring keys or passwords and it uses AWSs IAM authentication system instead. Pretty cool stuff honestly.
@Invigor: For my situation it was okay for the keys, but no I couldn't get it to work without providing keys. I tried skipping authentication. SSM should allow it to work without keys, but.... didn't really work for me. Got ssh errors instead. Let me know if you find a workaround
