Configuring winscp to use a proxy with ansible
vanderkerkoff
Wales
Hi there
We're currently configuring some Windows 2019 servers with ansible.
I currently need to tell WinSCP to use a proxy to gain external access, and was hoping there's a way to accomplish this using ansible so I can automate it.
Has anyone accomplished this in the past, or know a way to do this?
I'm thinking maybe run some powershell scripts on the machine once connected with ansible?
Any help or advice greatly appreciated.
V
Re: Configuring winscp to use a proxy with ansible
I'm not sure what you ask for.
WinSCP supports proxies. You can script WinSCP, both using simple WinSCP scripting or using WinSCP .NET assembly (e.g. from a PowerShell script).
https://winscp.net/eng/docs/guide_automation
https://winscp.net/eng/docs/library
WinSCP GUI can generate templates for both the script and .NET assembly for you:
https://winscp.net/eng/docs/ui_generateurl#script
vanderkerkoff
Wales
Hi Martin
Thanks for getting back to me
I'm looking through the links you've supplied, but not sure if they give me what I want.
When you open the GUI, you can enter a proxy server to use in all the communications that winscp uses. I'm looking for a way to enter those proxy details, but with a script, that I can run when I'm configuring the software on the servers automatically.
Does that explain it a bit better?
Thanks again for replying.
And this part of my answer didn't help?
