TransferSupport.State set to "On", but exits upon error
mcarner5
I have the TransferSupport.State in TransferOptions set to "On" yet if there is an issue, the script exits and I see this error:
Upload of FILENAME HERE failed: WinSCP.SessionRemoteException: Error transferring file 'FILENAME HERE'.
Unexpected error encountered. Please retry.
Permissions of  kept with their defaults
Timestamp of  kept with its default (current time)
Error: Exception calling "Check" with "0" argument(s): "Error transferring file 'FILENAME HERE'.
Unexpected error encountered. Please retry."
Am I improperly applying the TransferSupport state? Here is the script I am using:
# Load WinSCP .NET assembly
Add-Type -Path "WinSCPnet.dll"
# Session.FileTransferred event handler
function FileTransferred
    param($e)
    if ($e.Error -eq $Null)
        Write-Host "Upload of $($e.FileName) succeeded"
    else
        Write-Host "Upload of $($e.FileName) failed: $($e.Error)"
    if ($e.Chmod -ne $Null)
        if ($e.Chmod.Error -eq $Null)
            Write-Host "Permissions of $($e.Chmod.FileName) set to $($e.Chmod.FilePermissions)"
        else
            Write-Host "Setting permissions of $($e.Chmod.FileName) failed: $($e.Chmod.Error)"
    else
        Write-Host "Permissions of $($e.Destination) kept with their defaults"
    if ($e.Touch -ne $Null)
        if ($e.Touch.Error -eq $Null)
            Write-Host "Timestamp of $($e.Touch.FileName) set to $($e.Touch.LastWriteTime)"
        else
            Write-Host "Setting timestamp of $($e.Touch.FileName) failed: $($e.Touch.Error)"
    else
        # This should never happen during "local to remote" synchronization
        Write-Host "Timestamp of $($e.Destination) kept with its default (current time)"
function FileTransferProgress
    param($e)
    Write-Progress `
        -Id 1 -Activity $e.FileName -Status ("{0:P0} complete:" -f $e.FileProgress) `
        -PercentComplete ($e.FileProgress * 100)
try
    # Set up session options
        "sessionOptions here" = ""
    try
        # Will continuously report progress of synchronization
        $session.add_FileTransferred( { FileTransferred($_) } )
        # Will continuously report progress of transfer
        $session.add_FileTransferProgress( { FileTransferProgress($_) } )
        # Connect
        $transferOptions.ResumeSupport.State = [WinSCP.TransferResumeSupportState]::On
        # Synchronize files
        $synchronizationResult = $session.SynchronizeDirectories(
            [WinSCP.SynchronizationMode]::Remote,    #Remote is synced to match local
            "LOCAL", #Local repository
            "REMOTE",           #Remote repository
            $True,                                   #Delete remove files not in local repository
            $False,                                  #Do not sync in mirror mode
            [WinSCP.SynchronizationCriteria]::Time,  #Sync based on timestamp
            $transferOptions
        # Throw on any error
        $synchronizationResult.Check()
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch
    exit 1
mcarner
I may be understanding this wrong. Sounds like there is no support for this functionality in the .NET version.
Re: TransferSupport.State set to "On", but exits upon error
The "Unexpected error encountered. Please retry" most probably comes from the server. I cannot know what it means. Why do you think it has anything to do with TransferOptions.ResumeSupport?
Can you upload the file anyhow? Using WinSCP GUI? Using any other client?
