Lost all the lines of code inside a .php of a session
tripaparos
My .php file still exists but has nothings inside. I did some changes before and tried to save it but when i try to open it again everything was erased. Is there any way to find a previous session so i can restore it? My temp sessions are saved in the temp of winscp
Re: Lost all the lines of code inside a .php of a session
Did you try to locate the temporary copy of the file in your local temporary folder?
Can you reproduce the problem?
