Connection error when uploading file but works with vpn but very slowly
KeinMiner
So i have this problem since 3 months now and my Problem is :
When i try to upload my file to the Server [Zap-Hosting game server] it cant do it because connection failed but when i activate my vpn it works fine but is super slow any ideas to fix this. Yes i tried restarting the router and i talked with the Hoster and they had no clue.
Re: Connection error when uploading file but works with vpn but very slowly
Can you upload the files using any other client using the same protocol?
