Download files as folders
Yrais
When executing the session.Getfiles instead of downloading the files what I get is a folder with the name of the file and creates the folder Archive recursively until winscp times out. The folder archive is in the root of the ftp folder I'm accessing. I have the same command for multiple ftps and none of them have this problem.
Re: Download files as folders
