New option: Auto-touch files when using EDIT
programedit
I'm using a lot of times the functionality of EDIT files in remote SFTP servers. Mainly to edit code that I compile in a terminal shell opened to the same server. However, if the local and remote computers doesn't have identical clocks, when calling to make the file can have future times:
Warning: File 'main.c' has modification time 3.2 s in the future
This can be solved with a manual $ touch main.c in the shell. However, it's a pain when editing a lot of files.
So a simple solution can be to automatically touch an edited file after upload it.
Please, can you incorporate this functionality?
Regards.
programedit
Re: New option: Auto-touch files when using EDIT
Great! Thank you for the tip.
However, how I can disable this inside the current session? I'm opening WinSCP from another tool (using the command line), and when the session is open I want to disable (or enable) this option. Any idea?
programedit
Hi Martin,
This doesn't solve the problem! The problem is to ENABLE/DISABLE on-line, that's when the connection is stablished.
Please, can you add a button/menu-option/whatever to enable/disable it inside a session?
Thank you
Thank you
I'm lost.
I've already told you how to do this:
Just turn off "Preserve timestamp" transfer option. It has the effect you want.
https://winscp.net/eng/docs/ui_transfer_custom
programedit
Sorry, but I'm lost too. Please, with all due respect, listen to me, and I'm sorry if I'm being annoying... I can't found this option window! I repeat:
1. I open a WinSCP session using the command line (calling it from another tool, that is a Terminal).
2. Then inside the WinSCP I double click to EDIT a source file.
3. After editing a file I pick save, and the file is uploaded.
Then the question is: INSIDE THE SESSION, where I can configure this parameter?
Please, take note that I'm not transferring anything using TRANSFER buttons. I'm only EDITING.
So, please can you explain how I can do it?
Thank you for your patience.
programedit
Hi martin,
Finally I see it! I need to activate the "Transfer Settings" toolbar (Options->Toolbar->(enable)Transfer Settings), and then inside the listbox select "Configure". Inside this window I need to select the "Default" configuration, Duplicate it, and Edit. Inside I can disable the default "Common options"->"Preserve timestamp", save, return to the session window, and Select the duplicated "Default without preserver tiemstamp" Transfer Setting.
Very, very hard to found it... and not well documented. However, it works.
Thank you!
