list bookmarks for one click access
billatarcat
Can you display all your bookmarks in the GUI for one click access. Also, can you have a 'nickname' for each bookmark instead of a, sometimes, long url.
Thanks, WinSCP is a fiiiiiine product.
Bill
Re: list bookmarks for one click access
I do not understand.
You can switch to location profiles.
trapd
Displaying bookmarks
You can display the bookmarks dialog by double-clicking the blue bar where the current path is displayed. Not exactly 'single click' but easier than going through the menus. :)
Re: Displaying bookmarks
Well, there's also toolbar button for it.
seanr
FWIW, I'm a particularly big fan of how FlashFXP handles bookmarks. Haven't used WinSCP yet so I don't know if it already does the same, but clicking the bookmarks icon in FlashFXP gets you a popup menu listing all of the bookmarks and you can set bookmarks that will change both the local and remote folders at the same time. For me that's critical, because I manage several sites on a single server and need to change between them several times throughout the day so having to do each side separately would waste a lot of time. Basically, what I'd just about kill for is SCP built into FlashFXP or a client with an identical interface - I've never been happy with any of the other interfaces out there.
WinSCP supports this too. It's called "Location profiles".
