Suggestion: If else condition
Hi Team,
This is very nice app for code deployment into any web app using FTP deployment. Actually we are publishing the code using automation scripts by EOD. so we are using build and release for the code. So once we are deploying we are unable to check the folder name whether it is there or not(like we cant write if else condition . will develop the script for the if else condition ). so that it will be useful to many peoples who are struggling in automation to check those folders, if not there it helps in creating a new with same folder name.
Thanks in advance..hoping this feature is available in next release/update.
Regards,
Mukthiyar
Senior Management
Regards,
Mukthiyar
Senior Management
