Site folders
Sergey G
Site folders
Is there a way to manage site folders in the Sites Manager window? I would like to move the already existed folder to another but cannot do it. Only sites can be moved.
Re: Site folders
Indeed, site folders cannot be moved.
You will have to move the sites one-by-one.
If you have too many sites in the folder, you may rename the site keys in Windows registry export instead, if you are familiar with that.
Sergey G
Re: Site folders
thanks, it's helpful.
