Issue with synchronize remote
vs2019sv
NY
Hello
I am trying to run the following batch file from my computer.
It is not syncronizing all of the files to the dir.
How do I exclude hidden files and empty directories?
I am using the following script, but it does not seem to be working properly. Please advise
@echo off
  /log="C:\ccs\bin\WinSCP.log" ^
  /command ^
    "open sftp://username@10.10.1.1/ -hostkey=""ssh-rsa 1024"" -rawsettings ExcludeHiddenFiles=1 ExcludeEmptyDirectories=1 DeleteToRecycleBin=1 RecycleBinPath=""/usr/delete/winscprecycle""" ^
    "synchronize remote ""C:\Users\test\testdir"" /usr2/win/vs2019test/" ^
    "exit"
if %WINSCP_RESULT% equ 0 (
  echo Success
) else (
  echo Error
exit /b %WINSCP_RESULT%
Re: Issue with synchronize remote
Sorry, but "does not seem to be working properly" is not a good problem description. What problem do you have? Please attach a full session log file showing the problem (using the latest version of WinSCP).
