Error Could not retrieve directory listing........ No such file or director
ekuligow
CT
Trying to synchronize files between local server and remote server. Script returns below error and stops. I also cannot delete the directory using WinSCP GUI.
Error: Exception calling "Check" with "0" argument(s): "Error listing directory '/media/http/Creative/MiddleMarkets/13-MM-1795 - CAG Severe Snap Shot Video'.
/media/http/Creative/MiddleMarkets/13-MM-1795 - CAG Severe Snap Shot Video: No such file or directory"
Re: Error Could not retrieve directory listing........ No such file or director
Sorry, that's rather sparse problem description.
Where does the directory path come from? Is this the path your have specified for synchronization? Does it exist? Or does WinSCP get to that directory on its own? If it does, is it wrong and why?
