Destination empty
tiwas
Destination empty
Hi again,
I'm still playing with the scripts provided in the help section, and I have another problem I was hoping for help with.
This is from the debug window:
[DBG]: PS D:\WinSCP-5.17.2-Automation>> $transferResult = $session.GetFiles($sourcePath, $destPath, $False, $transferOptions)
[DBG]: PS D:\WinSCP-5.17.2-Automation>> $transferResult.Check()
Transfers
{/home/me/files/store/Downloaded.folder[Ident]/Downloaded.file.txt, /home/me/files/store/Another.Downloaded.Fold...
[DBG]: PS D:\WinSCP-5.17.2-Automation>> $transferResult.Transfers | Sort-Object -Property @{ Expression = { (Get-Item $_.Destination).LastWriteTime } } -Descending | Select-Object -First 1
Side        : Remote
Destination : \\192.168.x.x\file\store\local\Downloaded.folder[Ident]\Downloaded.file.txt
Touch       :
Chmod       :
Removal     :
FileName    : /home/me/files/store/Downloaded.folder[Ident]/Downloaded.file.txt
Error       :
[DBG]: PS D:\WinSCP-5.17.2-Automation>> Get-Item ($transferResult.Transfers | Sort-Object -Property @{ Expression = { (Get-Item $_.Destination).LastWriteTime } }  -Descending | Select-Object -First 1).Destination
[DBG]: PS D:\WinSCP-5.17.2-Automation>> (Get-Item ($transferResult.Transfers | Sort-Object -Property @{ Expression = { (Get-Item $_.Destination).LastWriteTime } }  -Descending | Select-Object -First 1).Destination).LastWriteTime
For some reason the Destination comes up empty, so the script shuts down.
This is the complete script so far (haven't played around with the try/catch parts yet...)
param (
    # Use Generate Session URL function to obtain a value for -sessionUrl parameter.
    $sessionUrl = "<removed>",
    $destPath = "X:\destination\path",
    $sourcePath = "/home/me/files/store/",
    #$listPath = "X:\destination\path\downloaded.txt",
    $sessionLogPath = $Null,
    $lastTimestamp = $Null,
    $timestampFile = "timestamp.dat",
    [Switch]
    $pause
try
    # Load WinSCP .NET assembly
    # Setup session options from URL
    $sessionOptions.ParseUrl($sessionUrl)
    Write-Host "Connecting..."
    while ($True)
        if (Test-Path $timestampFile)
            $lastTimestamp = [DateTime]::ParseExact((Get-Content $timestampFile), 'O', $Null)
        else
        Write-Host "Looking for new files..."
        if ($lastTimestamp -ne $Null)
            Write-Host "Downloading files modified after $lastTimestamp..."
            $transferOptions.FileMask = ("*>" + $lastTimestamp.ToString("yyyy-MM-dd HH:mm:ss") + "| *.mkv; *.avi")
        else
            Write-Host "Downloading all files..."
        # Find the latest downloaded file
        $latestTransfer =
            Sort-Object -Property @{ Expression = { (Get-Item $_.Destination).LastWriteTime } } `
                        -Descending |
        if ($latestTransfer -eq $Null)
            Write-Host "No files found."
        else
            $lastTimestamp = (Get-Item $latestTransfer.Destination).LastWriteTime
            Write-Host (
                "Downloaded $($transferResult.Transfers.Count) files, " +
                "latest being $($latestTransfer.FileName) with timestamp $lastTimestamp.")
        Set-Content -Path $timestampFile -Value $lastTimestamp.ToString("O")
        Write-Host "Waiting..."
        Start-Sleep -Seconds 60
catch
    $result = 1
# Pause if -pause switch was used
if ($pause)
exit $result
The code
Write-Host (
Results in the output
Downloaded 2 files, latest being /home/me/files/store/Downloaded.folder[Ident]/Downloaded.file.txt with timestamp .
Error: You cannot call a method on a null-valued expression.
tiwas
Is there a length limitation? I've played with shorter file names and it seems to work fine. The one giving me problems now is a total of 122 characters.
tiwas
No, it's definitely a character problem. Some of the directories have '[' and ']' in them, and that messes things up. Is there a way to overcome this? Or to replace certain characters? I've tried using the "transfer settings" to create the transfer options, but the check for "replace" doesn't result in any code as far as I can see and In any case there's nowhere to specify unwanted characters.
Re: Destination empty
Additionally: So the file \\192.168.x.x\file\store\local\Downloaded.folder[Ident]\Downloaded.file.txt was downloaded. Yet, calling $lastTimestamp = (Get-Item $latestTransfer.Destination).LastWriteTime yielded "null"? Do I understand right?
