Question about WinSCP.Session.GetFiles().Transfers
tiwas
Hi.
I've been playing around with some of the scripts here in order to set up continuous one-way file replication. This works incredibly well, and I'm stoked! Well, almost ;)
Thing is, as long as I only transfer files, there's only joy. If there are folders in the mix things get a little bit more tricky.
In my example, the folder has a newer timestamp than the files contained inside it. Why that is I have no idea, but it doesn't really matter. It's like that. Now, the code snippet (yes, I've removed code for brevity (?) and it's probably important) will test for the newest *file*. It will not take folders into account. And so it will continue to download empty folders.
Is there a way to also look for the folder timestamp?
Thanks!
$transferResult = $session.GetFiles($sourcePath, $destPath, $False, $transferOptions)
$latestTransfer =
   $transferResult.Transfers |
   Sort-Object -Property @{ Expression = { (Get-Item $_.Destination).LastWriteTime } } `
      -Descending |
   Select-Object -First 1
Re: Question about WinSCP.Session.GetFiles().Transfers
Sorry, I do not understand what your code is doing. So neither I understand your problem. Please give us more information. And more code.
tiwas
As you can see from the log, the transfer succeeds. The problem starts with this
$latestTransfer = $transferResult.Transfers | Sort-Object -Property @{ Expression = { (Get-Item $_.Destination).LastWriteTime } } `
-Descending | Select-Object -First 1
More specifically, the failure first happens here: Get-Item $_.Destination when there are '[' or ']' in the file name.
[DBG]: PS D:\WinSCP-5.17.2-Automation>> Get-Item $_.Destination
Get-Item : Cannot bind argument to parameter 'Path' because it is null.
At line:1 char:10
+ Get-Item $_.Destination
+ CategoryInfo : InvalidData: (:) [Get-Item], ParameterBindingValidationException
+ FullyQualifiedErrorId : ParameterArgumentValidationErrorNullNotAllowed,Microsoft.PowerShell.Commands.GetItemCommand
I'm new to powershell, but I'm pretty sure this is the culprit.
My solution, which in my book is just a band-aid is the following renaming of all files - but at least it doesn't crash:
Get-ChildItem $destPath -recurse | Rename-Item -NewName { $_.Name -replace '\[.*\]', '' }
$lastTimestamp = (Get-Item ($latestTransfer.Destination.ToString() -replace ('\[.*\]', ""))).LastWriteTime
  • session2.log (16.52 KB, Private file)
tiwas wrote:
But...WinSCP won't download files or folders with '{' or '}' in the name.
