Can I use Session.EnumerateRemoteFiles() in VBA?
ScruffR
I have browsed the forum and found some posts that stated it should be possible
(as in the final post in this thread https://winscp.net/forum/viewtopic.php?t=23824)
but in the docs I read
https://winscp.net/eng/docs/library_session_enumerateremotefiles
The method cannot be used via COM interface (i.e. from VBScript, JScript or VBA).
However, the outcome:
How would I check for the existence of a remote file of which I only know part of the name (e.g.
SomeFile_<YYYYMMDD_hhmmss>.CSV
where the timestamp cannot be predetermined).
I found that
FileExists()
cannot be used with wildcards and the common answer is to use
instead, but I'm always getting an Automation Error (-2146233079)
e.g.
' passing in "SomeFile_*.CSV" for fileName and a working session
Private Function resultExists(fileName As String, ByRef activeSession As Session) As Boolean
  Dim files As New RemoteFileInfoCollection
  Dim f As RemoteFileInfo
  ' error occures when the following statement is executed
  Set files = activeSession.EnumerateRemoteFiles("/somePath/", fileName, EnumerationOptions_None)
  resultExists = (files.count > 0)
  For Each f In files
    Debug.Print f.Name
  Next f
End Function
The problem doesn't seem to be the call itself but the assignment.
When I merely do
 call activeSession.EnumerateRemoteFiles("/somePath/", fileName, EnumerationOptions_None)
the call works, but I'm unable to "catch" the enumerator the call is supposed to return.
I'm on Win10 64bit Enterprise, MS Office 2016 64bit, WinSCPnet.dll (FileVersion 1.7.2.10240, ProductVersion 5.17.1.0)
Re: Can I use Session.EnumerateRemoteFiles() in VBA?
No you cannot. That other thread is probably some mistake. I'll edit it accordingly.
ScruffR
Thanks for the clarification, but how would one then go about checking for a specific but not fully qualified file without having to always needing to read the entire list of files stored in the directory?
And, is there any chance to get EnumerateRemoteFiles() working in VBA and/or FileExists() support wildcards ever?
There's no other way anyway. EnumerateRemoteFiles internally calls ListDirectory.
With most servers you need to retrieve full listing in any case (even if you use any other library).
ScruffR
I found a "workaround" that perfectly fits my needs and may also help others in a similar situation.
Since I need to archive the respective file(s) I'm looking for anyway I now do this
  Dim result As WinSCPnet.TransferOperationResult
  Set result = activeSession.GetFilesToDirectory(sftpPath, archivePath, fileNameWithWildcards)
  ' or when you want to remove the source file after archiving
  'Set result = activeSession.GetFilesToDirectory(sftpPath, archivePath, fileNameWithWildcards, True)
  ' ... error checks here
  If (result.IsSuccess()) Then
    Dim tea As WinSCPnet.TransferEventArgs
    For Each tea in resultTransfers
      Debug.Print tea.FileName
    Next tea
  End If
(BTW, I'm more a C++/C# guy anyway, but sometimes you need to please "customers" that insist in using VBA 😁)
