Saving last location on reloading the app..
james36@...
Go the errors below on quiting out of SCP when it was loading, but locked up (or appeared to be).. but it now seems it was just loading a large folder... still wouldn't expect error messages the next time you run it. Also, might be an idea to only load the first x number of items on reload, so it loads up, otherwise it just seems to lockup on reload. hence it was broken out of, which appears to cause it to error. Better to load lest (one screen load) and then continue with the rest once the app has loaded... so at least we know what it's doing.
WinSCP 5.17
(000070F0)
(00F85D26)
(00F87D8E)
(00F84B48)
(00087D7F) ntdll.dll
(000ABA7C)
(000AD3F0)
(00D8B1E8)
(000ABB04)
(000AC41D)
(000AC16A)
(00002658)
(00F83D39)
Status: unknown_rel_addr
Re: Saving last location on reloading the app..
