Disconnected: No supported authentication methods available (server sent: )
ElliottDavidson
Manchester
I'm only a simple user, so I apologise in advance if I've missed anything
Getting a weird issue where sometimes the server refuses connection, sometimes it doesn't but details aren't changed. I'm using SFTP and a password to connect
Logs are
. 2020-03-09 11:41:47.481 WinSCP Version 5.15.2 (Build 9590) (OS 10.0.17763 - Windows 10 Enterprise)
. 2020-03-09 11:41:47.481 Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\
. 2020-03-09 11:41:47.481 Log level: Normal
. 2020-03-09 11:41:47.481 Local account: APOLLOGLOBAL\EDavidson
. 2020-03-09 11:41:47.481 Working directory: C:\Program Files (x86)\WinSCP
. 2020-03-09 11:41:47.481 Process ID: 9032
. 2020-03-09 11:41:47.481 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe"
. 2020-03-09 11:41:47.481 Time zone: Current: GMT+0, Standard: GMT+0 (GMT Standard Time), DST: GMT+1 (GMT Daylight Time), DST Start: 29/03/2020, DST End: 25/10/2020
. 2020-03-09 11:41:47.481 Login time: 09 March 2020 11:41:47
. 2020-03-09 11:41:47.481 --------------------------------------------------------------------------
. 2020-03-09 11:41:47.481 Session name: Marketin* Cloud (Site)
. 2020-03-09 11:41:47.481 Host name: ftp1.exacttarget.com (Port: 22)
. 2020-03-09 11:41:47.481 User name: 10965573 (Password: Yes, Key file: No, Passphrase: No)
. 2020-03-09 11:41:47.481 Tunnel: No
. 2020-03-09 11:41:47.481 Transfer Protocol: SFTP
. 2020-03-09 11:41:47.481 Ping type: Off, Ping interval: 30 sec; Timeout: 15 sec
. 2020-03-09 11:41:47.481 Disable Nagle: No
. 2020-03-09 11:41:47.481 Proxy: None
. 2020-03-09 11:41:47.481 Send buffer: 262144
. 2020-03-09 11:41:47.481 SSH protocol version: 2; Compression: Yes
. 2020-03-09 11:41:47.481 Bypass authentication: No
. 2020-03-09 11:41:47.481 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: Yes
. 2020-03-09 11:41:47.481 GSSAPI: Forwarding: No; Libs: gssapi32,sspi,custom; Custom:
. 2020-03-09 11:41:47.481 Ciphers: aes,chacha20,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2020-03-09 11:41:47.481 KEX: ecdh,dh-gex-sha1,dh-group14-sha1,rsa,WARN,dh-group1-sha1
. 2020-03-09 11:41:47.481 SSH Bugs: Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto
. 2020-03-09 11:41:47.481 Simple channel: Yes
. 2020-03-09 11:41:47.481 Return code variable: Autodetect; Lookup user groups: Auto
. 2020-03-09 11:41:47.481 Shell: default
. 2020-03-09 11:41:47.481 EOL: LF, UTF: Auto
. 2020-03-09 11:41:47.481 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes; Follow directory symlinks: No
. 2020-03-09 11:41:47.481 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No; Exit code 1 is error: No
. 2020-03-09 11:41:47.481 SFTP Bugs: Auto,Auto
. 2020-03-09 11:41:47.481 SFTP Server: default
. 2020-03-09 11:41:47.481 Local directory: H:\, Remote directory: /, Update: Yes, Cache: Yes
. 2020-03-09 11:41:47.481 Cache directory changes: Yes, Permanent: Yes
. 2020-03-09 11:41:47.481 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2020-03-09 11:41:47.481 DST mode: Win
. 2020-03-09 11:41:47.543 Looking up host "ftp1.exacttarget.com" for SSH connection
. 2020-03-09 11:41:47.543 Connecting to 66.231.91.46 port 22
. 2020-03-09 11:41:47.682 We claim version: SSH-2.0-WinSCP_release_5.15.2
. 2020-03-09 11:41:47.799 Server version: SSH-2.0-1.82_sshlib GlobalSCAPE
. 2020-03-09 11:41:47.799 Using SSH protocol version 2
. 2020-03-09 11:41:47.799 Have a known host key of type dss
. 2020-03-09 11:41:47.799 Doing Diffie-Hellman group exchange
. 2020-03-09 11:41:48.016 Doing Diffie-Hellman key exchange with hash SHA-1
. 2020-03-09 11:41:48.248 Host key fingerprint is:
. 2020-03-09 11:41:48.248 ssh-dss 1024 4d:c0:8b:26:ed:fe:f5:fa:78:d6:78:cc:dc:99:90:af c3BYah4Q/WWmuQK8ybEfVyj2AzdyIhPG0YjrWUtvcdA=
. 2020-03-09 11:41:48.286 Host key matches cached key
. 2020-03-09 11:41:48.286 Initialised AES-256 SDCTR client->server encryption
. 2020-03-09 11:41:48.286 Initialised HMAC-SHA-256 client->server MAC algorithm
. 2020-03-09 11:41:48.286 Initialised zlib (RFC1950) compression
. 2020-03-09 11:41:48.286 Initialised AES-256 SDCTR server->client encryption
. 2020-03-09 11:41:48.286 Initialised HMAC-SHA-256 server->client MAC algorithm
. 2020-03-09 11:41:48.286 Initialised zlib (RFC1950) decompression
! 2020-03-09 11:41:48.504 Using username "10965573".
. 2020-03-09 11:41:48.666 Server offered these authentication methods: password,publickey
. 2020-03-09 11:41:48.666 Prompt (password, "SSH password", <no instructions>, "&Password: ")
. 2020-03-09 11:41:48.666 Using stored password.
. 2020-03-09 11:41:48.673 Sent password
. 2020-03-09 11:41:48.790 Password authentication failed
! 2020-03-09 11:41:48.790 Access denied
. 2020-03-09 11:41:48.853 Server offered these authentication methods:
. 2020-03-09 11:41:48.853 Disconnected: No supported authentication methods available (server sent: )
* 2020-03-09 11:41:48.891 (EFatal) Disconnected: No supported authentication methods available (server sent: )
* 2020-03-09 11:41:48.891 Authentication log (see session log for details):
* 2020-03-09 11:41:48.891 Using username "10965573".
* 2020-03-09 11:41:48.891 Access denied.
* 2020-03-09 11:41:48.891 Authentication failed.
I can't seem to find a case prior where it's got "Server sent: ", usually it seems to be Key related
Kind Regards, Elliott
Re: Disconnected: No supported authentication methods available (server sent: )
Can you post also a log file of a successful connection?
Though you better contact your server administrator.
ElliottDavidson
Manchester
Thanks for the response Martin!
2020-03-09 16:00:55.955 Looking up host "ftp1.exacttarget.com" for SSH connection
. 2020-03-09 16:00:55.956 Connecting to 66.231.91.46 port 22
. 2020-03-09 16:00:56.102 We claim version: SSH-2.0-WinSCP_release_5.15.9
. 2020-03-09 16:00:56.231 Server version: SSH-2.0-1.82_sshlib GlobalSCAPE
. 2020-03-09 16:00:56.231 Using SSH protocol version 2
. 2020-03-09 16:00:56.231 Have a known host key of type dss
. 2020-03-09 16:00:56.232 Doing Diffie-Hellman group exchange
. 2020-03-09 16:00:56.431 Doing Diffie-Hellman key exchange with hash SHA-1
. 2020-03-09 16:00:56.622 Host key fingerprint is:
. 2020-03-09 16:00:56.622 ssh-dss 1024 4d:c0:8b:26:ed:fe:f5:fa:78:d6:78:cc:dc:99:90:af c3BYah4Q/WWmuQK8ybEfVyj2AzdyIhPG0YjrWUtvcdA=
. 2020-03-09 16:00:56.659 Host key matches cached key
. 2020-03-09 16:00:56.660 Initialised AES-256 SDCTR client->server encryption
. 2020-03-09 16:00:56.660 Initialised HMAC-SHA-256 client->server MAC algorithm
. 2020-03-09 16:00:56.660 Initialised AES-256 SDCTR server->client encryption
. 2020-03-09 16:00:56.660 Initialised HMAC-SHA-256 server->client MAC algorithm
! 2020-03-09 16:00:56.859 Using username "10965573".
. 2020-03-09 16:00:57.853 Server offered these authentication methods: password,publickey
. 2020-03-09 16:00:57.853 Prompt (password, "SSH password", <no instructions>, "&Password: ")
. 2020-03-09 16:00:57.853 Using stored password.
. 2020-03-09 16:00:57.864 Sent password
. 2020-03-09 16:00:57.969 Access granted
. 2020-03-09 16:00:57.969 Opening session as main channel
. 2020-03-09 16:00:58.070 Opened main channel
. 2020-03-09 16:00:58.270 Started a shell/command
. 2020-03-09 16:00:58.315 --------------------------------------------------------------------------
. 2020-03-09 16:00:58.315 Using SFTP protocol.
. 2020-03-09 16:00:58.315 Doing startup conversation with host.
> 2020-03-09 16:00:58.326 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2020-03-09 16:00:58.426 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2020-03-09 16:00:58.426 SFTP version 3 negotiated.
. 2020-03-09 16:00:58.426 We believe the server has signed timestamps bug
. 2020-03-09 16:00:58.426 We will use UTF-8 strings until server sends an invalid UTF-8 string as with SFTP version 3 and older UTF-8 strings are not mandatory
. 2020-03-09 16:00:58.426 Changing directory to "/Import".
. 2020-03-09 16:00:58.426 Getting real path for '/Import'
> 2020-03-09 16:00:58.426 Type: SSH_FXP_REALPATH, Size: 16, Number: 16
< 2020-03-09 16:00:58.527 Type: SSH_FXP_NAME, Size: 35, Number: 16
. 2020-03-09 16:00:58.527 Real path is '/Import'
. 2020-03-09 16:00:58.527 Trying to open directory "/Import".
> 2020-03-09 16:00:58.527 Type: SSH_FXP_LSTAT, Size: 16, Number: 263
< 2020-03-09 16:00:58.628 Type: SSH_FXP_ATTRS, Size: 21, Number: 263
. 2020-03-09 16:00:58.628 Getting current directory name.
. 2020-03-09 16:00:58.707 Listing directory "/Import".
> 2020-03-09 16:00:58.707 Type: SSH_FXP_OPENDIR, Size: 16, Number: 523
< 2020-03-09 16:00:59.220 Type: SSH_FXP_HANDLE, Size: 10, Number: 523
> 2020-03-09 16:00:59.220 Type: SSH_FXP_READDIR, Size: 10, Number: 780
< 2020-03-09 16:01:00.936 Type: SSH_FXP_NAME, Size: 107017, Number: 780
> 2020-03-09 16:01:00.936 Type: SSH_FXP_READDIR, Size: 10, Number: 1036
< 2020-03-09 16:01:01.846 Type: SSH_FXP_NAME, Size: 107017, Number: 1036
> 2020-03-09 16:01:01.846 Type: SSH_FXP_READDIR, Size: 10, Number: 1292
< 2020-03-09 16:01:02.557 Type: SSH_FXP_NAME, Size: 107017, Number: 1292
> 2020-03-09 16:01:02.557 Type: SSH_FXP_READDIR, Size: 10, Number: 1548
< 2020-03-09 16:01:03.366 Type: SSH_FXP_NAME, Size: 106827, Number: 1548
> 2020-03-09 16:01:03.366 Type: SSH_FXP_READDIR, Size: 10, Number: 1804
< 2020-03-09 16:01:18.490 Type: SSH_FXP_NAME, Size: 21795, Number: 1804
> 2020-03-09 16:01:18.490 Type: SSH_FXP_READDIR, Size: 10, Number: 2060
< 2020-03-09 16:01:18.600 Type: SSH_FXP_STATUS, Size: 22, Number: 2060
< 2020-03-09 16:01:18.600 Status code: 1
> 2020-03-09 16:01:18.600 Type: SSH_FXP_CLOSE, Size: 10, Number: 2308
Thank you!
As I wrote before, you should contact your server administrator.
This does not seem like a problem of WinSCP.
