Failed to set tab
ttgzs_wt@...
Failed to set tab
WinSCP 5.17.1
Failed to set tab "root@192.168.100.104 " at index 0
(002A5A31) Vcl::Comctrls::_16736
(002A7F26) Vcl::Comctrls::TPageControl::UpdateTab
(002A73DD) Vcl::Comctrls::TTabSheet::CMTextChanged
(00274A0C) Vcl::Controls::TControl::Perform
(00272865) Vcl::Controls::TControl::SetTextBuf
(00020E08) TCustomScpExplorerForm::UpdateSessionTab
(00020B70) TCustomScpExplorerForm::DoTerminalListChanged
dmvukobr@...
Failed to set tab
WinSCP 5.17.3
Failed to set tab "dmvukobr@web07p.lib.purdue.edu " at index 1
(002A5C99) Vcl::Comctrls::_16736
(002A818E) Vcl::Comctrls::TPageControl::UpdateTab
(002A7645) Vcl::Comctrls::TTabSheet::CMTextChanged
(00279B7D) Vcl::Controls::TWinControl::WndProc
(00274C74) Vcl::Controls::TControl::Perform
(00272ACD) Vcl::Controls::TControl::SetTextBuf
Re: Failed to set tab
tech@...
Failed to set tab
WinSCP 5.17.3
Failed to set tab "sysadmin@web01.ofb.local " at index 0
ich@...
Failed to set tab
WinSCP 5.17.6
Failed to set tab "Neue Sitzung" at index 1
(002A5F81) Vcl::Comctrls::_16736
(002A8476) Vcl::Comctrls::TPageControl::UpdateTab
(002A779F) Vcl::Comctrls::TTabSheet::SetImageIndex
(00020B74) TCustomScpExplorerForm::DoTerminalListChanged
kusniryukigor@...
Failed to set tab
WinSCP 5.17.2
Failed to set tab "root@192.168.96.18 " at index 1
Трассировка стека:
kami911@...
Failed to set tab
WinSCP 5.17.9
Failed to set tab "developer@mvh-webportal-teszt.mvh.local " at index 0
Veremkivonat:
(002A6E0D) Vcl::Comctrls::_16736
(002A9302) Vcl::Comctrls::TPageControl::UpdateTab
(002A87B9) Vcl::Comctrls::TTabSheet::CMTextChanged
(0027ACF1) Vcl::Controls::TWinControl::WndProc
(00275DE8) Vcl::Controls::TControl::Perform
(00273C41) Vcl::Controls::TControl::SetTextBuf
(00020E50) TCustomScpExplorerForm::UpdateSessionTab
(00020BB8) TCustomScpExplorerForm::DoTerminalListChanged
thomas.laible@...
Failed to set tab
WinSCP 5.17.10
Failed to set tab "root@172.19.203.68 " at index 0
Stapelverfolgung:
(002A6E31) Vcl::Comctrls::_16736
(002A9326) Vcl::Comctrls::TPageControl::UpdateTab
(002A87DD) Vcl::Comctrls::TTabSheet::CMTextChanged
(00275E0C) Vcl::Controls::TControl::Perform
(00273C65) Vcl::Controls::TControl::SetTextBuf
Use RDM free, after Update, the Massage happens whenever winscp is called from the app
dzhon.zojdberg@...
Failed to set tab
WinSCP 5.19.2
Failed to set tab "root@192.168.0.40 " at index 0
(002AC371) Vcl::Comctrls::_16736
(002AE866) Vcl::Comctrls::TPageControl::UpdateTab
(002ADD1D) Vcl::Comctrls::TTabSheet::CMTextChanged
(00280255) Vcl::Controls::TWinControl::WndProc
(0027B34C) Vcl::Controls::TControl::Perform
(002791A5) Vcl::Controls::TControl::SetTextBuf
(00021484) TCustomScpExplorerForm::UpdateSessionTab
(000211EC) TCustomScpExplorerForm::DoTerminalListChanged
xynta222@...
Failed to set tab
WinSCP 6.1.1
Failed to set tab "root@31.129.104.53 " at index 1
Трассировка стека:
(004223F9) Vcl::Comctrls::_16736
(004248EE) Vcl::Comctrls::TPageControl::UpdateTab
(00423DA5) Vcl::Comctrls::TTabSheet::CMTextChanged
(003F13D4) Vcl::Controls::TControl::Perform
(003EF22D) Vcl::Controls::TControl::SetTextBuf
(00C8F4C3) TThemeTabSheet::UpdateCaption
(00C8F23B) TThemeTabSheet::SetBaseCaption
(00023FD6) TCustomScpExplorerForm::UpdateSessionTab
(00023BC6) TCustomScpExplorerForm::SessionListChanged
saulo.lima@...
Failed to set tab
WinSCP 6.5.2
Failed to set tab "Nova Aba " at index 1
Rastreamento de pilha:
(00401941) Vcl::Comctrls::_16747
(00404216) Vcl::Comctrls::TPageControl::UpdateTab
(00403624) Vcl::Comctrls::TTabSheet::CMTextChanged
(0039DEE0) Vcl::Controls::TControl::Perform
(0039BBB9) Vcl::Controls::TControl::SetTextBuf
(00BAF86B) TThemeTabSheet::UpdateCaption
(00BAF902) TThemeTabSheet::SetCaptionTruncation
(00025529) TCustomScpExplorerForm::SessionListChanged
@saulo.lima: Thanks for your report.
mohsen6558@...
Failed to set tab
WinSCP 6.5.3
Failed to set tab "root@192.168.1.3 " at index 1
(00BB0287) TThemeTabSheet::UpdateCaption
(00BAFFD7) TThemeTabSheet::SetBaseCaption
(00025972) TCustomScpExplorerForm::UpdateSessionTab
(00025536) TCustomScpExplorerForm::SessionListChanged
@mohsen6558: Thanks for your report.
stefan.wilfling@...
Failed to set tab
Tried to open a new WinSCP-Session (worked in older versions) from navigation menu (doubleklick in navigation).
Version: 2026.1.16.0 64-bit (PreJIT)
WinSCP 6.5.5
Failed to set tab "Neuer Tab " at index 1
Stapelverfolgung:
(00401A59) Vcl::Comctrls::_16747
(0040432E) Vcl::Comctrls::TPageControl::UpdateTab
(00403513) Vcl::Comctrls::TTabSheet::SetImageIndex
kyquan.nguyen14@...
Failed to set tab
WinSCP 6.5.7
Failed to set tab "New Tab " at index 1
