Error Exception :Error deleting file 'myFiles'. After resumable file upload
Abdullah_Mukhtar
Pakistan
While uploading file using WinSCP .NET library following error occurred:
Error Exception :Error deleting file 'myFiles'. After resumable file upload the existing destination file must be deleted. If you do not have permissions to delete file destination file, you need to disable resumable file transfers.
Error code: 4
Error message from server: Failure
Bellow is my code
    session.Open(sessionOptions);
    Console.WriteLine("Connection Successful...");
    RemoteDirectoryInfo directoryInfo = session.ListDirectory("/");
    // Upload files
    transferOptions.TransferMode = TransferMode.Binary;
    TransferOperationResult transferResult;
    if (File.Exists(stFileName))
        transferResult = session.PutFiles(stFileName, RemoteFolderPath, false, transferOptions);
        // Throw on any error
        transferResult.Check();
        // Print results
        foreach (TransferEventArgs transfer in transferResult.Transfers)
            Console.WriteLine("Upload of {0} succeeded", transfer.FileName);
    else
        Console.WriteLine("File not found : " + stFileName);
Re: Error Exception :Error deleting file 'myFiles'. After resumable file upload
What is your question?
Do you or do you not have the permissions to delete the file?
Are you asking how to disable the resumable transfer? Or are you asking why do you get the error?
