Get files .csv from zip folder
amybi77
Hi All
I am using CLI , the issue i am facing is the .csv files are in a zip folder, here is my code. Looked online for 2 days and couldn't find a way to deal with the zip files
please need help
option batch on
open sftp://un:pwd@server/ -hostkey="ssh-rsa 1024 xxxxxxxxxxx"
cd /users/dev
option transfer binary
get -preservetime *.csv c:\
close
Re: Get files .csv from zip folder
Technically, there's nothing like a ZIP folder. If you mean that your CSV files are in a ZIP archive, then you need to download the archive and extract it after your WinSCP download script finishes.
