Are Multi-Stream SFTP Processes?
ChrisEDI
LaGrange L2
I need 8 SFTP processes that will need to run when documents are in the folders.
How can this be accomplished?
I am familiar with the command line scripting and using the windows task scheduler to kick them off.
I guess I am asking if there is a listener in WinSCP or the possibility of one?
If not, can multiple SFTP processes be run at the same time?
Re: Are Multi-Stream SFTP Processes?
Sorry, I do not understand what you ask for. "Listener" for what? What do you mean by "when documents are in the folders"?
