Issue after windows update: WinSCP process terminated with exit code -1073741502 (C0000142).
ikrax
After windows update on host machine we get error from winSCP while trying to connect to FTP server.
Error:
WinSCP process terminated with exit code -1073741502 (C0000142). There was no output. Response log file C:\\Users\\DefaultAppPool\\AppData\\Local\\Temp\\wscp1BDC.020150CB.tmp was not created. This could indicate lack of write permissions to the log folder or problems starting WinSCP itself
Re: Issue after windows update: WinSCP process terminated with exit code -1073741502 (C0000142).
What do you mean by "host machine"? The machine where you run WinSCP? Or the machine where you connect to?
How are you using the WinSCP .NET assembly?
