SFTP file from server
talormanda
USA
try
    # Load WinSCP .NET assembly
    Add-Type -Path "C:\ProgramData\Microsoft\AppV\Client\Integration\76D73676-A43A-4890-9049-8283D31CD7E0\Root\VFS\ProgramFilesX86\WinSCP\WinSCPnet.dll"
    # Setup session options
        HostName = "servername"
        UserName = "mgr"
        Password = "password"
        SshHostKeyFingerprint = "ssh-ed25519 256 #stuff_here#"
    try
        # Connect
        # Download files
        $transferResult =
            $session.GetFiles("/sunquest/printfiles/testfile.txt", "C:\test", $False, $transferOptions)
        # Throw on any error
        $transferResult.Check()
        # Print results
            Write-Host "Download of $($transfer.FileName) succeeded"
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch [Exception]
    exit 1
I am getting the following error after running the above:
Error: Cannot initialize external console.
Request event
System Error. Code: 2.
The system cannot find the file specified
If I connect to the server via WinSCP normally, I can access the path and touch the file. I am unsure what is wrong. Could it be that my starting directory for the account is in /sunquest/mgr , and I have to change directories somehow?
Can you post debug log file (Session.DebugLogPath) for that?
Why do you have the DLL in that path? (C:\ProgramData\Microsoft\AppV\...)
