Winscp Generated Powershell script not passing the Password for sftp connection login
fawwazab
Saudi arabia
dears greeting
I have a request to automate an sftp file transfer and I used the generate code facility to generate a powershell script as you can see below the issue is that the script works fine when I run it manually and after I added the PPK file and saved the passphrase using WinSCP Pageant but the same script not working when I automate running it, it stops when the passphrase required and as I said it is already saved in the WinSCP pageant on the same server.
script
& "C:\Program Files (x86)\WinSCP\WinSCP.com" `
  /log="C:\writable\path\to\log\WinSCP.log" /ini=nul `
  /command `
    "open sftp://116_XXX_XXX:PASSWORD@mftuat.XXX.com/ -hostkey=`"`"ssh-rsa 1024 dz/EkPjAcHgvAwpKjAf6RCQ9+8hwPoiCKROEamN6Edw=`"`" -privatekey=`"`"D:\WinSCP\UAT_116_XXX_XXX.ppk`"`" -rawsettings ProxyMethod=3 ProxyHost=`"`"proxy.XXX.XXX`"`" ProxyPort=8080" `
    "put -delete C:\Simah\test1.txt /upload/TR/DATALOAD/" `
    "exit"
$winscpResult = $LastExitCode
if ($winscpResult -eq 0)
  Write-Host "Success"
else
  Write-Host "Error"
exit $winscpResult
log :
. 2020-02-03 15:56:20.369 Leaving host lookup to proxy of "mftuat.XXX.com" (for SSH connection)
. 2020-02-03 15:56:20.369 Will use HTTP proxy at proxy.XXX.XXX:8080 to connect to mftuat.XXX.com:22
. 2020-02-03 15:56:20.369 Looking up host "proxy.XXX.XXX" for proxy
. 2020-02-03 15:56:20.369 Connecting to HTTP proxy at 10.XXX.XXX.10 port 8080
. 2020-02-03 15:56:20.369 Connecting to 10.XXX.XXX.10 port 8080
. 2020-02-03 15:56:20.369 We claim version: SSH-2.0-WinSCP_release_5.15.9
. 2020-02-03 15:56:20.447 Server version: SSH-2.0-InformaticaMFT10.2.2
. 2020-02-03 15:56:20.447 Using SSH protocol version 2
. 2020-02-03 15:56:20.447 Have a known host key of type rsa2
. 2020-02-03 15:56:20.463 Doing ECDH key exchange with curve nistp256 and hash SHA-256
. 2020-02-03 15:56:20.541 Server also has ssh-dss host key, but we don't know it
. 2020-02-03 15:56:20.541 Host key fingerprint is:
. 2020-02-03 15:56:20.541 ssh-rsa 1024 ab:46:60:59:73:66:50:cf:50:d2:d1:56:95:db:c9:c5 dz/EkPjAcHgvAwpKjAf6RCQ9+8hwPoiCKROEamN6Edw=
. 2020-02-03 15:56:20.541 Host key matches configured key
. 2020-02-03 15:56:20.541 Initialised AES-256 CBC client->server encryption
. 2020-02-03 15:56:20.541 Initialised HMAC-SHA1 client->server MAC algorithm
. 2020-02-03 15:56:20.557 Initialised AES-256 CBC server->client encryption
. 2020-02-03 15:56:20.557 Initialised HMAC-SHA1 server->client MAC algorithm
. 2020-02-03 15:56:20.588 Reading key file "D:\WinSCP\UAT_116_XXX_XXX.ppk"
! 2020-02-03 15:56:20.588 Using username "116_XXX_XXX".
. 2020-02-03 15:56:20.760 Server offered these authentication methods: password,publickey,keyboard-interactive
. 2020-02-03 15:56:20.760 Offered public key
. 2020-02-03 15:56:20.791 Offer of public key accepted
! 2020-02-03 15:56:20.791 Authenticating with public key "imported-openssh-key"
. 2020-02-03 15:56:20.791 Prompt (passphrase, "SSH key passphrase", <no instructions>, "Passphrase for key "imported-openssh-key": ")
! 2020-02-03 15:56:30.869 Wrong passphrase
. 2020-02-03 15:56:30.869 Prompt (passphrase, "SSH key passphrase", <no instructions>, "Passphrase for key "imported-openssh-key": ")
. 2020-02-03 15:56:40.963 Authentication failed.
Error
fawwazab
hi martin thanks for the reply and yes I read it and I don't see something applies to my issue as all of the steps were handled with the used for running the script but still the reason for me is unknown I really need a help on this issue and by the way I am using control m for automating running the script
I do not know anything about "control m", so I cannot tell what's wrong. Though I'm pretty sure it is the same problem as with Windows Task Scheduler. Pageant should not be used for automation.
