Error transferring file Copying files to remote side failed
DomBurf
UK
I'm automating an upload of our web site from our local build server to our Azure remote hosting. I'm using the following commands to do this.
option batch abort
option transfer binary
open ftp://myusername:mypassword@domain/site/wwwroot
cd /site/wwwroot
ls
synchronize remote -delete "E:\buildfolder" /site/wwwroot
close
However I'm getting the following errors:
Error transferring file web.config.
Access is denied.
I have tried running my script from the build server command line and from the build itself and it fails for both. I can upload the files manually via FileZilla though. I would prefer to make this a build task rather than a manual one. Any ideas?
2020-01-31 08_15_10-TFS Server (as admin) (192.168.0.18) - Remote Desktop Connection Manager v2.7.png
Re: Error transferring file Copying files to remote side failed
A log file from FileZilla for a comparison would be helpful too.
lord_steph
having the same problem, what exactly was the fix, please
i get the same exact error - winscp copying to remote side failed
DomBurf
Re: having the same problem, what exactly was the fix, please
The file was open and WinSCP couldn't copy the file. I had to close the file before the copy.
