403 Forbidden
avalencia
Mexico
403 Forbidden
Hello I hope you can help me, I try to connect to pass a file to my Amazon bucket, through the graphic interface I do it without problem, but when I take out the command and run it through CMD I can't open the connection. I set the log with some attempts to connect cmd and by PowerShell.
Re: 403 Forbidden
Do you have any special characters in your secret access key?
Make sure you encode them properly:
https://winscp.net/eng/docs/session_url#special
Or have WinSCP generate the script/code from your working GUI session:
https://winscp.net/eng/docs/ui_generateurl#script
Non-encoded credentials can be provided using -password switch:
https://winscp.net/eng/docs/scriptcommand_open#password
