Avoiding accidental DIR moves
beggers
Las Vegas
Is there a setting that will allow to block or at least prompt if I accidently try to move a DIR? I'm asking because I have a condition called "Essential Tremors" which causes my hand to shake just a tiny bit but often this is enough to really mess things up! Thanks for any suggestions!
Re: Avoiding accidental DIR moves
Does it happen in a file list? Or in a directory tree?
Does it happen when you actually try to move a file, but you grab a directory by mistake? Or do you grab a directory, when you just want to click the directory? (you do not actually intend to grab anything)
Local or remote panel?
For remote panel, you can enable move confirmations in Preferences.
It's somewhat unclear, as it's part of
Drag&drop operations and paste to other applications
