WinSCP-5.16.6.RC-Setup.exe is not a valid Win32 application.
billybangleballs
UK
Hi Martin,
I've downloaded WinSCP-5.16.6.RC-Setup.exe from you and cdn, both files are the same but both give the error message WinSCP-5.16.6.RC-Setup.exe is not a valid Win32 application.
I'm using win xp sp3 and I'm currently running Version 5.15.2(Build 9590)
Does the new version still support XP?
Thanks.
Re: WinSCP-5.16.6.RC-Setup.exe is not a valid Win32 application.
Installer of WinSCP 5.16 does not support Windows XP/2003 anymore.
WinSCP application itself still does work on Windows XP.
You can use Portable executables download to get the application without using the installer.
https://winscp.net/eng/downloads.php#stable_portablezip
I have updated the documentation to cover this:
https://winscp.net/eng/docs/requirements#client
