Problems to upload multiples Files
alsahe26
I use the method "PutFilesToDirectory" for upload an all files in a folder (approximately 600-700) but after some minutes, get this message:
Error transferring file ....
Copying files to remote side failed
Connection closed; aborted transfer of ...
Can somebody help me about that?
Re: Problems to upload multiples Files
